No, the front wheel lights stay unlit but the auto and rear wheels are lit along with the Check light (I stated Error before but it is Check). If you add the resistor mod then I think the TOD computer is fooled into thinking everything is fine and the front wheel indicators light up normally even though no power is being routed to the wheels. The PO of my VX just put a toggle switch in under the passenger seat but I think I will wire it up to a 4WD switch that I have to make it a little more finished.
There's no 'I' in denial.
I was thinking that because the rear is being driven the front will be spinning too, even though it's not being sent power. I think someone confirmed this via a GoPro camera recently. In your toad mode both front and rear are disconnected so the TC shouldn't get any input from the output so to speak.
I like that the MPG improves a little, it is not real important but it would be nice to get a little better MPG. Where did you get the TOD off switch? How hard was it to install, how long did it take?
So you have less miles on the odometer than you have driven? Strange that the odometer does not count miles when the TOD is off.
VXorado, does your VX do the same thing?
I hooked up the scanner and got a code, P0705 Transaxle Range Switch Circuit. I am not sure what part this is but I am going to try an find what the malfunction is by doing some searches.
If anyone knows what the best course of action should be to correct this problem please do tell me. In the mean time I will be searching.
Edit:
I found this http://engine-codes.com/tsb/tsb.php?...tsb_make=isuzu
ISUZU Technical Service Bulletin for Code P0705
Bulletin Number: IB00S007 Bulletin - Date: 2000-02-01
Component: Unknown Or Other
Summary:
On suv vehicles with automatic transmissions, some remote starter installations may cause the malfunction indicator light to set and store p0705. American Isuzu motors does not sell remote starter kits and does not recommend any particular model.
Read more: http://engine-codes.com/tsb/tsb.php?...#ixzz2dz2Vq6rw
I also found this thread:
http://www.vehicross.info/forums/showthread.php?t=14908
It appears to be part 8-96017-511-0 "Neutral Safety Switch"
I can get it but I would like to know where it goes and how hard it is to replace. I tried to search the shop manual I downloaded on line but it is not searchable and is just hundreds of scanned pages. Does anyone know what pages have the repair procedure on it? or a good picture of it's location?
My VX manual shows DTC P0705 Transmission Range Switch
(Mode Switch) Illegal Position . . . . . . . . . . . . 7A1 30
First thing I'd check is the 15A fuse (CB 15) in the engine compartment. According to the manual "This fuse can burn due to a short circuit in the backup lamp." Does your back up light come on?
Also, Tom's toad mode has the rear drive shaft disconnected which is why his odometer doesn't advance while being towed.
I also run manual hubs/TOD off switch. Works well and I average 1-2 MPG better with TOD off and hubs unlocked. I did thorough testing last winter to check for MPG differences and it's always slightly improved with TOD off.
I have the resistor installed and I don't get a checklight, just some whacking illuminations on the front wheels. Typically, all three front wheel bars will light up and hold.
I ran just manual hubs for a while and I definitely recommend the TOD off switch. The t-case will still try to transfer power to the front wheels and you'll feel the loss of power if the hubs are unlocked. This was common for highway driving when accelerating... TOD would try to transfer extra power to the front wheels I would end up accelerating slower.
