Results 1 to 15 of 21
Thread: Transmission, TOD and hub questions.
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    Gear Transmission, TOD and hub questions.
    First let me tell you all that I have done many searches and found lots of threads about these items but there is so many pages to read and I have read them for hours and still not found the specific info I am looking for that is why I posted this thread.
    I have been having a strange transmission glitch lately and from what I have found it might be the transmission pressure control solenoid, it shifts hard into second and then shifts hard from second to first when slowing down. It has only done this a couple of times and after I pulled over and shut if off it starts acting normal again. A few times, I have noticed the indicator on the dash has flashed from drive to neutral as I take off or when I am sitting at a light. I will try to see if I can get a code, I have a code reader.
    With that going on with the transmission, I have been doing some research about the TOD, transmission, and hubs on the VX and I have some question about that too.
    I have always wanted to have the 2-wheel drive option as being in full time 4-wheel drive uses more gas, wears out parts and it is just not necessary to have all the time. Here in the Denver area, it is dry most of the time and I would like to have the 2-wheel drive option if it did not have any adverse effects and there was a benefit to doing the manual hubs. So to all of you that have done the manual hub swap here are a few questions:
    1. What benefits have you found having the manual hubs?
    2. Have you had any issues with the drive train using them?
    3. Do you know if it affects the TOD system in a good or bad way? Or does it not affect it at all?
    4. If you leave them locked, does it just work like a normal stock VX?
    5. Do I need the TOD off switch I have read about to do the manual hubs?
    If so can you tell me what it is, how it works, do you make it, or can I buy one, and where it would be installed on the VX?
    I did find this thread about the TOD but there is not much about how it worked out after they did it, and the pictures are gone too. In addition, if you have manual hubs why would you need the off switch?
    http://www.vehicross.info/modules.ph...warticle&id=74
    Please let me know how the manual hubs have worked for you and tell me any information I may not have thought of and asked about that might be helpful.
    My VX has 60K, 16� wheels with new Dura-Track tires 245/75 R16, the torsion bars were cranked up about 1� on the left and 1.5� on the right as it was not even when I got it now both sides are at the same ride height.
    Thanks,
    Chris
    '01 Ebony #0939
    I was going to suggest that you speak with Fizx regarding your TOD/Manual hub questions, but I see that you've already asked in his For Sale thread, so my only other suggestion at this point about the problems you're experiencing (especially what your trans indicator lights on the dash are doing) would be to remove and inspect your Mode Selector switch from the drivers side of the transmission to see if it's dirty and can be cleaned, and/or possibly just needs to be replaced.
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    I will check out the Mode Selector switch and see if it is dirty, how do I tell if it is bad?
    I was hoping to hear from Fizx as my fried was interested in his VX and I was hoping he would tell me about the hubs, maybe he is busy and will get back to me at some point. Until then I am hoping for some good info from the rest of the VX community.
    Thanks
    '01 Ebony #0939
    Quote Originally Posted by CatFish View Post
    Unfortunately, from what I've seen in various threads, about the only way to tell for sure if it's causing the problems is to take it off, clean it, then reinstall it to see if the problem goes away. I've not had one apart myself to see how the electrical traces on it's circuit board are arranged, but being an electrical switch, it might be possible to following the traces on the board to determine which contacts should show continuity depending on what position the switch is in.
    From some of the pictures of mode switches I've seen here in various threads, it looks like the switches sometimes just get built up with road grime and such, which then causes short circuits between adjacent contacts (which results in the erratic light displays on the dash board and the trans going into gears other than the ones that are currently selected).
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    Thanks for the info I will check it out this weekend and see what I find.
    For me, the sole purpose of installing the manual hubs was so that I could tow the VX '4 down' behind the RV. Of course, I also had to install a quick disconnect on the rear driveshaft for that.
    I seriously doubt that you'll see a significant increase in mpg after installing manual hubs. The jury is still out on that one but I didn't see any improvement. I didn't install the TOD 'off' switch'.
    None at all. My TOD light was flashing before I put on the manual hubs ... & it still does.
    In my experience ... not at all (of course that's a statistical sample of 'one').
    Yes
    I don't have the switch. Mebbe sometime in the future but so far it just wasn't worth the effort.
    Thanks,
    Chris
    Chris,
    I was worried about running the manual hubs with the TOD because I just didn't like the idea of power being applied to the front differential with no load. That ended up being an unfounded concern. So far it's worked out great for me. I think I did a How2 on the install. Lemme know if you need it.
    Nov 2012
    I have the TOD on/off switch with no manual hubs. The switch was installed by the previous owner and doesn't have the resistor mod so when the TOD is bypassed I get an error light under the TOD display. This doesn't bother me because it gives me an indication that I'm in 2WD, otherwise the only way I know is by rear wheel slippage. I don't see any reason to go with manual hubs unless you have a locker or plan on towing like Tom mentioned.
    Scott
    There's no 'I' in denial.
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    Chris,
    Scott
    Thanks for the info guys, sounds like I can just install the TOD off switch and get what I want.
    Scott, when you have the TOD off do the lights for the front wheels in the TOD display still light up?
    Nov 2012
    No, the front wheel lights stay unlit but the auto and rear wheels are lit along with the Check light (I stated Error before but it is Check). If you add the resistor mod then I think the TOD computer is fooled into thinking everything is fine and the front wheel indicators light up normally even though no power is being routed to the wheels. The PO of my VX just put a toggle switch in under the passenger seat but I think I will wire it up to a 4WD switch that I have to make it a little more finished.
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    OK so the front wheel lights stay off indicating they are not in use so I could get rid of the error the front wheel light not lighting would tell me the VX in in 2WD with out the error light. are you sure the front wheels light up with the resistor mod? I would think they would stay off?
    I think I will use the blank slot next to the heated mirror switch on the console for the TOD off switch location. I am going to see if I can get one with a light in it so I will know when it is on or off.
    Now to troubleshoot the trans issue and find a TOD off switch and learn how to install it it.
    Nov 2012
    Yes, with the resistor mod the error light will turn off but I think I read that the front wheel indicators light up as if the wheels are being powered. I don't know for sure though.
    Exactly my thought too. I'll have to check my 4WD switch to see if it has a lamp in it.
    5 spd mod will fix it.
    Not Zakly.
    If you're going for maximum mpg, then you'll still need the locking hubs. Without them, you're still spinning the 3rd member in your front diff & hence the front prop shaft. That'll eat up a little bit of your mpg.
    Nov 2012
    Not Zakly.
    I think the spinning of the 3rd happens anyway due to drag in the TC. There is probably a little more drag at the wheels though without disconnecting the hubs.
    I also run manual hubs/TOD off switch. Works well and I average 1-2 MPG better with TOD off and hubs unlocked. I did thorough testing last winter to check for MPG differences and it's always slightly improved with TOD off.
    I have the resistor installed and I don't get a checklight, just some whacking illuminations on the front wheels. Typically, all three front wheel bars will light up and hold.
    I ran just manual hubs for a while and I definitely recommend the TOD off switch. The t-case will still try to transfer power to the front wheels and you'll feel the loss of power if the hubs are unlocked. This was common for highway driving when accelerating... TOD would try to transfer extra power to the front wheels I would end up accelerating slower.
    When VX is in 'Toad Mode', I get 0 miles accumulation on the odometer. I'm interpreting that to mean that nothing is making it into the tranny from either the front prop or the rear (not even a negligable turning due to viscous coupling).
  1. Need mechanic help... Transmission questions
    By wintermute in forum VX Troubleshooting...
    Last Post: 04/20/2013, 12:33 PM
  2. Transmission questions
    By mikemol in forum VX Troubleshooting...
    Last Post: 09/16/2012, 10:50 PM
  3. tod questions
    By pbkid in forum VX Talk...
    Last Post: 08/12/2008, 01:16 PM
  4. Transmission Fluid Questions
    By WyldWeasel in forum VX Troubleshooting...
    Last Post: 04/10/2006, 04:02 PM
  5. Questions
    By Apostle in forum VX Talk...
    Last Post: 10/06/2003, 11:44 PM
