First let me tell you all that I have done many searches and found lots of threads about these items but there is so many pages to read and I have read them for hours and still not found the specific info I am looking for that is why I posted this thread.
I have been having a strange transmission glitch lately and from what I have found it might be the transmission pressure control solenoid, it shifts hard into second and then shifts hard from second to first when slowing down. It has only done this a couple of times and after I pulled over and shut if off it starts acting normal again. A few times, I have noticed the indicator on the dash has flashed from drive to neutral as I take off or when I am sitting at a light. I will try to see if I can get a code, I have a code reader.
With that going on with the transmission, I have been doing some research about the TOD, transmission, and hubs on the VX and I have some question about that too.
I have always wanted to have the 2-wheel drive option as being in full time 4-wheel drive uses more gas, wears out parts and it is just not necessary to have all the time. Here in the Denver area, it is dry most of the time and I would like to have the 2-wheel drive option if it did not have any adverse effects and there was a benefit to doing the manual hubs. So to all of you that have done the manual hub swap here are a few questions:
1. What benefits have you found having the manual hubs?
2. Have you had any issues with the drive train using them?
3. Do you know if it affects the TOD system in a good or bad way? Or does it not affect it at all?
4. If you leave them locked, does it just work like a normal stock VX?
5. Do I need the TOD off switch I have read about to do the manual hubs?
If so can you tell me what it is, how it works, do you make it, or can I buy one, and where it would be installed on the VX?
I did find this thread about the TOD but there is not much about how it worked out after they did it, and the pictures are gone too. In addition, if you have manual hubs why would you need the off switch?
http://www.vehicross.info/modules.ph...warticle&id=74
Please let me know how the manual hubs have worked for you and tell me any information I may not have thought of and asked about that might be helpful.
My VX has 60K, 16” wheels with new Dura-Track tires 245/75 R16, the torsion bars were cranked up about 1” on the left and 1.5” on the right as it was not even when I got it now both sides are at the same ride height.
Thanks,
Chris
