Results 1 to 5 of 5
Thread: stuck front axleshaft
    Mar 2011
    1999 Black VX, #1094
    Can't pull axleshaft from diff. on the right side. Is there something holding it from the inside of diff. Any suggestions will be appreciated.
    Check for ABS sensor cables. I think they need to be pulled first.
    Gregg
    2001 Proton Yellow #1379
    Aug 2007
    1999 Ebony 0156
    if you are talking about the front passenger axle it has a retaining clip on the end inside the diff' you have to tear front housing apart to get to the clip' there is also an oilseal that will need to be replaced if you went to town on trying to pull the axle out'. napa sellsd the oil seal' it is the same seal for a 1997 rodeo. found all this out the hard way
    2 things are infinite,the universe and human stupidity, I'm not sure about the former. Alb.Einstein
    ^^^What he said!
  1. Still stuck
    By glenngw3 in forum VX Troubleshooting...
    Last Post: 01/07/2014, 01:00 PM
  2. Stuck in 4x4
    Last Post: 12/31/2013, 08:45 AM
  3. Stuck
    By slutty22 in forum VX Talk...
    Last Post: 07/20/2009, 07:13 PM
  4. I am stuck...
    Last Post: 05/18/2009, 07:14 AM
  5. Stuck
    By bobmumgaard in forum VX Talk...
    Last Post: 03/27/2006, 04:17 AM
