Results 1 to 5 of 5
Thread: TOD Check Light/vibration
    Mar 2011
    1999 Black VX, #1094
    TOD Check Light came on and steering seems to bind up when turning sharp. There's also a popping sound/feeling at front right tire when turning. All tire lights come on the tod screen and check light blinks. Please suggest what I need to check? Thank you all.
    '01 Ebony #0939
    Quote Originally Posted by glenngw3 View Post
    My first thought is the front right CV joint. If it's broken, the TOD sensor ring isn't going to turn as consistently as the sensor rings on the other three wheels, and that kind of inconsistency between readings would cause the TOD Check Light to come on. Have you looked to see if the boot on the front right CV is ripped, or compared by hand how it feels to the front left?
    Mar 2011
    Boot is ripped all the way around
    '01 Ebony #0939
    If the current CV's are originals and you decide it's time to replace both of them (the one with the ripped boot is obviously ready for replacement), make sure to compare the original sensor rings to the sensor rings on the replacement CV's for overall condition.
    The last time I replaced the CV's on my FWD car, I noticed that the ABS sensor rings on the new CV's weren't near the quality of the originals (not to mention that a lot of the individual teeth were smashed, dented, and generally irregular), so I had both sets of rings pressed off then had the originals pressed onto the newer CV axles thinking that they would at least provide a better signal trace for the pickups.
    You'll probably hear different trains of thought about whether it's better to replace both CV's (front left and front right) at the same time, or, to take an if-it's-not-broke-don't-fix-it approach and just replace the obviously broken one, but unless you can actually find an OEM replacement, I usually try to stick with the current OEM stuff as long as it's still working since it usually seems to be better made.
    glen,
    If your CV is making that much noise, it's going to fail ... soon. I had an outer CV blow up on mine so I know.
    You can remove that 1/2 shaft so you can keep driving it till you get the replacement. I drove that way for a few months with no problem.
  1. tod check light
    Last Post: 11/10/2016, 04:16 PM
  2. check TOD light
    By fred78 in forum VX Troubleshooting...
    Last Post: 10/20/2014, 01:45 PM
  3. check light and abs
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 05/28/2013, 05:23 AM
  4. TOD Check Light On JDV VX
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 06/04/2009, 10:46 AM
  5. Tod Check Light Help!!!
    By ron in forum VX Troubleshooting...
    Last Post: 07/02/2007, 11:56 PM
