Results 1 to 15 of 47
Thread: Major Engine Problem
Threaded View
  1. #11
    2000 Dragon Green VX 0485
    Here's a LINK describing possible 3.5 eng problems. Isuzu knows about this but contimues to deny everything.
    http://forums.delphiforums.com/itog/messages?msg=996.35
    Dragon Bob
    The Isuzu service bulletin regarding excessive oil consumption (> 1qt per
    1000 miles) is service bulletin # IB00-01-5002. As I said on the phone, if
    you ever get to a point where you feel oil consumption is an issue, Isuzu
    will consider up to 1qt per 1000 miles to be "within spec". If your
    consumption gets worse than that, they will have the the dealership perform
    monitored consumption tests (per the service bulletin above) and if the oil
    consumption is then measured worse than 1 qt per 1000 miles, Isuzu is
    obligated to replace the motor. Having this service bulletin number at your
    disposal is valuable because it shows your dealership that you know what is
    going on. Tuck it away and hope you never have to use it.
  1. Oh no, engine problem
    Last Post: 10/17/2012, 05:04 AM
  2. Possible engine problem?
    By Exclamation in forum VX Troubleshooting...
    Last Post: 11/03/2011, 01:07 PM
  3. Major Problem.....
    By 9tinyfingaz in forum VX Troubleshooting...
    Last Post: 05/08/2007, 05:18 PM
  4. Possible Major Problem!!!!!!!!!!!!
    By climbcovey in forum VX Troubleshooting...
    Last Post: 12/13/2006, 12:55 PM
  5. major ABS problem
    Last Post: 03/27/2004, 12:31 PM
