Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: tranny hesitation
  1. #16
    Mar 2012
    sold
    DO NOT FLUSH THE TRANSMISSION!!! Doing so seems to lead to problems. I have changed both my VX's to Amsoil Synthetic with no problems, one at 103,000 miles and one at 150,000 miles, but I sure as heck did not flush them! A filter change can only help...
    lol yeah dont worry ive heard nothing but horror stories about high mileage flushes
  2. #17
    IMHO, running the tranny through the gears with no fluid in it to push out every last dribble is a really bad idea too. Just drain out what you can and fill her up again.
  3. #18
    if you dont mind me asking how much for fluid and filter change? did you have them flush or just change? for the pros: could i do a filter change and fluid change safely at home myself?
    I brought my own synthetic ATF. Total deal was $150 with new filer. Cross member bar was a bitch to get off.
    Scott
  4. #19
    Jul 2009
    Yeah, those eight bolts holding it to the frame rails can really get rusty above the weldnuts inside the mounting brackets. With no way to get to them in there, heat is your only friend...and possibly a lucky shot of rust release through one of the several holes that allow all that sand and moisture in there in the first place!
    Vixer Fixer
  5. #20
    1999,silver,vehicross,1891
    I'm seeing more and more tranny related problems on here; my posts from last year's disaster and my opinion on the General Motor's 4L30E tranny we all have not being suited to our VX's power or 4WD all the time is well known.
    Scott in MA, I bet your shop didn't drop your crossmember, with a lift it can be gotten around, else it's a huge risk to take it off for a shop, on mine, I think 6 of 8 bolts broke off making in mandatory to weld into the ports on the ends of the member to access the other side of the remaining bolts and knock them out. What a nitemare. I guess alot of members that have always owned and service their on VX's got to those threads before they rusted/welded themselves together. I never did until tranny failed. I did my filter, gaskets and all when I bought my VX in 2006 w/o thinking about dropping the cross member. Patients and it can be gotten to. I just bet most shops would not.
    We should all also install real intercoolers, the factory cooler thats part of the radiator is a joke, it's nothing but a single flow thru conduit on the bottom of the radiator that has no fins. With the VX being 4WD all the time, cooling the liquid for the sake of the hundreds of fine machined and tiny parts inside our tranny's is paramount.
    My method of flushing transmission is to let them drip naturally for several days, fluid never stops running out ever after days. I by-passed the radiator altogether, just left it sealed. I hope your problem is fixed but I encourage everyone to occationally call a local tranny shop, do not tell them you have a VX, just say you'd like to know a flat rate re-build price on a GM 4L30E. If that's Greek to them, hang up. If they understand it, maybe stop by and see their shop. The one thing a good tranny shop needs is lots and lots and lots of table stop space. Once your tranny is dis-assembled I bet you could lay it out on a tennis court. Re-build starts with the cleaning and inspection of each part. On mine, even my case had worn points/grooves at certain input points that required a new case, all this was covered as I had been qouted a flat rate price well under $2000.
  1. Hesitation
    By bartmanS4 in forum VX Troubleshooting...
    Last Post: 06/17/2013, 12:17 PM
  2. RPM hesitation
    Last Post: 06/11/2008, 06:08 AM
  3. outline of tranny filter on tranny pan......
    Last Post: 05/16/2006, 08:44 PM
  4. motor hesitation
    By military vx'r in forum VX Troubleshooting...
    Last Post: 05/08/2004, 09:26 AM
  5. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 03:41 AM
