here are some pics of the insta lube kit installed..
it was a bit tricky finding a spot for the tank..
had to make a bracket for the mounting hardware that came with it
and the tank installed
here is a shot of the t fitting for the inlet hose and sender unit
the gauge on the tank showing the pressure
and a final install shot tucked under the air inlet pipe and maf sensor
