I also firmly believe that you should NOT run through the gears with the engine running to drain out every last drop of the old tranny fluid. Too many members have had their tranny go FUBAR after the fluid change using that process ... & besides, it just sounds like a really bad idea anyway.
My $0.02 ... & I want change back![]()
