Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: A Different Window Problem
  1. #16
    Nov 2003
    '99 Ironman 1405
    Quote Originally Posted by ahdoman View Post
    ...But, the real problem I was having was with the rubber track in the front....
    Your problem description sure sounded like what I'm experiencing, the front rubber tracks binding the windows when being raised. Think I'll run your solution by the shop techs. Thanks.
  2. #17
    Jul 2014
    2001 Pearl White Vehicross 1455
    I also bent the front track SLIGHTLY so the window aligns better. Do this last after everything else. You'll need to run the window up and down to test it. If you bend it incorrectly you'll hear the window bind. Small bends make a big difference. My windows move so freely now there's no need for lube. I was able to wipe the rubber clean and it's plenty slippery without any lube.
    Current caretaker of The elusive 2001 "Pearl White" VX - The last one.
    1988 BMW 325ic
  3. #18
    Pic of the front window track.
    Can see scratch marks where I used pliers to widen it. I also angled it slightly just as ahdoman mentions above.
    All this was written up by "Phines" several years ago. He had pics as well.
    It relieves/reduces the friction between the glass edge and the rubber molding the glass fits into, so it won't bind/"pinch" and slow down the upward movement of the glass.
    Many owners have had the window MOTOR burn out after years of it trying to raise the glass against this friction.
  4. #19
    Nov 2003
    '99 Ironman 1405
    Thanks, VX KAT. Guess one benefit of having a late blooming windows problem is there's a ton of info about possible fixes.
  1. window problem
    Last Post: 04/15/2012, 09:45 PM
  2. A weird window problem
    By ameetw in forum VX Troubleshooting...
    Last Post: 10/18/2008, 12:19 PM
  3. Another Window Problem!!!
    By ronin7586 in forum VX Troubleshooting...
    Last Post: 10/11/2008, 11:23 AM
  4. window tilt problem
    By zzzyang in forum VX Talk...
    Last Post: 02/28/2004, 06:08 AM
  5. VX Window Problem
    By VX Monster in forum VX Troubleshooting...
    Last Post: 07/29/2003, 09:20 AM
