A Different Window Problem
					I have scoured the existing threads and yet as much as there is here on the subject I haven't seen this problem.
My passenger window was closed when I got out of the VX the other day.
I went back 20 minutes later and it was half open.
Attempting to raise the window conventionally had no effect except a clicking sound.  I then tried down on the control button and it opened completely. It would not go back up. Just the clicking as I toggled the button up and down.
I came to the forum, searched, and started reading page after page.
I learned how to remove the door panel and did.
My white plastic clips are fine.  It seems that however the cable attached to the cross member that the white plastic clips and window are mounted to has broke and/or separated.  The clicking sound is when a small metal block on the cable rolls over the top pulley on the regulator.  With this metal block at the top I can raise and lower the window manually.  I can even lower it electrically as when the block descends it engages the window support and lowers as it should.  When I use the button with the block at the bottom, it cables to the top and makes that clicking sound as it rolls over the top pulley. Also, with the block at the bottom, I can't move the window manually.  The block appears to engage and work properly lowering the window but fails to engage properly when raising the window.
Has anyone had this problem?
I'm wondering if it can be repaired or if a new regulator is the only solution?
I was able to close the window to seal the interior from the elements with the creative application of a 12" bungee cord.
I appreciate any input... Thanks!
Jeff
				Jeff
2001 Dragon, 2-90 Celica AllTrac Turbos, 1997 4 Runner
