I think I have been misunderstood. The release is a small flat rubber covered electric switch that would be at the finger tips on the right side of the license plate where you pull on the door. When activated (alarm disarmed), pulling on the door open (thus triggering the electric switch) would activate a typical solenoid release, thus opening the door the same way a Scion TC, or XB trunk release or a corvette C6 door opens. I get Scions in my shop all the time with the license plate panel broken off because when the alarm is active and the switch is not powered they pull the whole panel off.
