So I had to change the starter out and (of course) when I took apart the exhaust the gaskets were shot. I bought gaskets from carids and partsgeek that were labelled as being for a vehicross and neither of sets fit. I also noticed that the one on the driver's side seems to be a bigger diameter hole (either that or the bolts are spaced further away). I cannot find anything on a part number for the actual sizes we need or dimensions for the gaskets we use. I'm not talking about the flange gasket further up toward the manifold. I'm talking about the ones further down the pipe that you have to remove to change the starter. I'm picturing myself passing out at a stop light from fumes leaking into the cabIt seems like the gaskets have to be the exact size because there appears to be a metal ring in the middle of the gaskets that needs to set just right where the pipes butt up against each other. Before anyone asks, I'm in Juneau Alaska and none of the muffler shops carry the gaskets. Neither does O'reilly or Napa here. I've now burnt $70 on gaskets and shipping from ordering on-line and still have leaky pipes.
