Well, I've been suffering with a problem that seems to defy easy resolution. I was hoping maybe you folks might have a suggestion. When I put my VX in park and try to remove the ignition key it sticks. I have to ram the shifter hard against the stop to get the key out. Over time, and not surprisingly, this has begun to weaken the shifter handle. So I'm afraid that before too long I am going to end up with a broken shifter handle, or a permanently stuck key...or probably both.
The first question I have is directed at anyone who has faced a similar issue. What are my best options to fix the !#% shift lock mechanism so it doesn't do this? The next question I have regards the shifter handle itself. I brought my VX to my regular mechanic and he said "no, it's too far gone, you really can't fix it". Okay. So what does that leave? Has anyone replaced the shifter with something more sturdy? I don't care so much for originality. My VX already has a 3.5" lift with big beefy mudders etc. I just want it to function. Maybe there is a holistic solution that solves both problems? Wouldn't that be cool!
Any insight/suggestions would be sincerely appreciated.
