Results 1 to 10 of 10
Thread: torque converter bolts HELP!!!
    Sep 2010
    1999 silver vx 0250
    i have been working on gettin my engine out and have hit a snag...i can not seem to get a wrench on the torque converter bolts,off set or regular box end..
    i cant even tell what size they are 16 seems too small 17 seems too big???
    im loosing my mind here!!!!
    anyone every get these off on a transmission or engine removal??please let me know how you did it
    thanx
    ken
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    I had a wrench that was welded with an off set and it worked great, it was a 17mm, you are welcome to use but cann't get it to you till 2morrow, have too much to do today after work. hit me up with PM.
    01, LineX tan/black, 1055
    Would one of those flex head ratchets work?
    Sep 2010
    1999 silver vx 0250
    no not enuff clearence and the bolt head is real close to the rim of the fly wheel??
    99 Silver 515
    Special tool
    I also had to have a friend make a special tool. IIRC is was the end of a socket cut in half and welded to a openend/boxend wrench. Don't recall the size, but 17mm sounds right. If Giz can't get it to you let me know and I will drop mine in the mail.
    Dan
    Nov 2012
    If I remember correctly I pulled the starter bolts out and was able to used a ratchet with an extra long extension. This made it quite easy to remove the bolts.
    There's no 'I' in denial.
    Sep 2010
    1999 silver vx 0250
    giz and hugh thanx for the offer to mail me ur wrenches to help me out but before i did that i bought a 3 dollar 17 mm wrench
    cut the box end off and welded it to the shaft of the wrench..
    perfect off set!!!
    had the torque converter bolts off in under 5 min!!!
    thanx for the help!!
    Love it!
    Quote Originally Posted by vxfocus View Post
    ... i bought a 3 dollar 17 mm wrench ... cut the box end off and welded it to the shaft of the wrench..
    perfect off set!!!
    Now that's my kind of Enginerd-ing!!!
    Sounds like the time I bought a $30 spanner socket ... & took a grinder to it before I used it for the first time. BTW, did I mention that I have the perfect tool to tighten your hub nuts to set the pre-load on the front bearings if anyone ever needs to borrow it.
    Feb 2010
    that's close to what I had, so great work.
  1. torque converter and overdrive sensor
    By Axelivan in forum VX Troubleshooting...
    Last Post: 07/18/2011, 08:42 PM
  2. Catalytic Converter
    By KristyRemo in forum VX Troubleshooting...
    Last Post: 12/27/2007, 04:30 PM
  3. Transmission Torque Converter Clutch Solenoid Issue
    By VehiGator in forum VX Troubleshooting...
    Last Post: 07/14/2006, 10:53 PM
  4. Torque Converter Clutch
    By scarpezio in forum VX Talk...
    Last Post: 03/12/2005, 09:37 AM
  5. Torque converter question
    By VX1 in forum VX Troubleshooting...
    Last Post: 07/17/2003, 06:50 PM
