Hey Sue, I didn't read through every reply here, but honestly, I agree with Giz. It does not look like you bent the frame mounting piece that holds the LCA bushing.
From what I see, you should replace your LCA with a straight one, get new LCA bushings, and have all that installed.
I just checked car-part.com and it looks like the late model Rodeo LCAs are the same as they come up in the search....looks as cheap as $35.
I think you should leave the frame alone unless there really is significant damage, which does not appear to be the case.
