Sue, you took one hard hit on that LCA and that can transmit to anything it's attached to. In the VX's case, that happens to be a cast bracket that once tweaked cannot be staightened and expected to survive. Any reputable frame shop or repair facility won't take that risk. The reason your go-to guy won't just weld in a new bracket is because it's very tricky welding cast metal to formed steel. That's why he's opting for cutting out the frame and bracket assembly and welding in a salvaged assembly from a yard. It really makes sense from a safety standpoint and I commend him for calling it like it is...sorry the news isn't better!![]()
