Results 1 to 15 of 75
Thread: Advice on Lower Control Arm damage & repair
    Quote Originally Posted by Knigh7s View Post
    Ouch... Murphy's Law... All that protection under there and you get hit where it hurts...
    So it is that piece I circled in my pic. Hopefully it's a bit easier that having to cut a section out... If it's not to hot out tomorrow, I'm gonna try swapping out my front rotors, I'll take a closer look at that section.
    Thanks Adam-Lee! (I forget which name you go by ).
    Appreciate the input/info!
    yeah, tell me about Murphy's law
    Sep 2010
    1999 white iron man 1728
    What about a good front end/ frame shop? Get a good LCA and they could heat and pull that bracket back to specs. Then do the alignment .
    '01 Ebony #0939
    Quote Originally Posted by bigblock8396375 View Post
    I'm with bigblock. If that section of the frame is actually bent/tweaked, you shouldn't have any problem finding a shop with frame straightening equipment that could un-tweak that one small section. You own repair guys could then replace the bolt on parts, although if your own guys don't have the equipment to do the alignment, you might be better off (save yourself some time and running back and forth) just having the frame shop do everything.
    That must have been a good sized pebble is all I can say.
    My shop does alignments, but don't think they do frame work. I'm thinking I should start by making appt, give him some time to assess it, instead of the quicky look yesterday.
    I'll also start checking around for a frame place.
    I think it happened when I came off a ledge and couldn't/didn't see the large drop, and landed on a "pebble" (). The dent does look pretty much like a round type shape.
    Hiya Sue
    Sent you an e-mail.
    Jo
  1. A note on lower ball joint / control arm bolts
    Last Post: 01/06/2014, 05:06 PM
  2. Did I damage my VX?
    By Chef in forum VX Talk...
    Last Post: 02/07/2006, 09:22 AM
  3. Damage to VX
    Last Post: 07/21/2004, 02:51 PM
  4. Taking to Dealership for repair- Need Advice
    By EclipseGSX in forum VX Troubleshooting...
    Last Post: 10/24/2003, 02:22 PM
  5. Hail damage
    By RobVX in forum VX Talk...
    Last Post: 04/07/2003, 01:02 PM
