Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 75
Thread: Advice on Lower Control Arm damage & repair
    Had my guy do a quicky assessment today on the lower control arm damage from Moab.
    Said piece that connects to LCA is also tweaked/bent (circled).
    Told me to get:
    The frame piece from A-arm forward. He'll cut the brackets on the frame. And a new ($300 new or replacement) LCA.
    1) What is part # in schematic for piece above LCA? Is it #1, STEERING KNUCKLE? ($568 NEW ) (Schematic at bottom of post)
    2) Searching salvage yards shows 96-97 Rodeos/Passport are same/will fit. ANYBODY KNOW? Obviously there's plenty of them locally I can get.
    3) Think a salvage yard will PULL the LCA and the other part for me?
    4) If so, how much would be fairly reasonable for them to pull it?
    5) Took more pics showing different angles - input/comments on what you see?
    6) Thoughts/opinions on this repair/replace plan?
    DIFFERENT ANGLES ON DAMAGE
    LOOKING STRAIGHT UP
    UNDAMAGED SIDE FOR COMPARISON
    Jan 2006
    If you are referring to the green circle as #1 in your schematic, thats doesn't look like the part. That would be the one that is right behind the rotor cover. Would it be whatever is connected to #25 bushing that you are looking for? TBH, I can't even find that piece in the parts catalog either.
    PG 3C-12 and 3C?19 in the Workshop Manual
    No part number anywhere. Is it welded to the frame? Or is it bolted? Hard to tell from your pictures.
    It's the part outlined here, I think he said it's the frame. I'm not quite sure if it's the entire part in green, or if he wants just red part, but I think it's welded to the green.
    This part is bolted to the lower control arm with purple bolt/nut.
    I remember him saying something like he needs the frame in front of the steering box (or something like that). Does that make any sense? (Obviously I need to talk to him again and get it clarified).
    Sounds like he's saying he needs to chop a piece of the frame out here out of mine, including the vertical piece (green) that's tweeked, and get the same chunk from a donor and he'll weld it into place, and then bolt it to a new A-arm.
    I'm way outta my league here, so I have no idea.
    Sounds like it's gonna cost a fortune - - -
    I need to check with the VXers that have spare part trucks, see if they can "cut" this piece out for me - - - anybody have Rent-a-torch handy? etfren, Jo, vxfocus ??
    Jan 2006
    Ouch... Murphy's Law... All that protection under there and you get hit where it hurts...
    So it is that piece I circled in my pic. Hopefully it's a bit easier that having to cut a section out... If it's not to hot out tomorrow, I'm gonna try swapping out my front rotors, I'll take a closer look at that section.
    Quote Originally Posted by Knigh7s View Post
    Thanks Adam-Lee! (I forget which name you go by ).
    Appreciate the input/info!
    yeah, tell me about Murphy's law
    Sep 2010
    1999 white iron man 1728
    What about a good front end/ frame shop? Get a good LCA and they could heat and pull that bracket back to specs. Then do the alignment .
    Hey Sue,
    I'm in exactly the same conundrum as you! Plus more
    I bent my lower arm and it wrapped the metal around that mounting point. Not sure yet what the full extent of the damage is but I have an appointment on Tuesday to get it looked at.
    Disclaimer: DON'T DO KANE CREEK STOCK.....
    Make it yours, but make it classy........ unless theres zombies.........thats when the gun rack goes in.
    Quote Originally Posted by ND92 View Post
    I did Kane Creek stock with no problem... eleven years ago! Great trail, but I took home some "trail trophies" the last time I did it (with rock sliders, skid plates, lift, and bigger tires). Yes, some trails are getting tougher and the old 1-5 rating system is out of date. However, a stock vehicle can sill do most of the old 3 or 3.5 trails. Just be careful, go slow, and have a good spotter. I did Steel Bender... sorry, Hello Kitty Canyon... before my VX was lifted. I bumped and scraped quite a bit, but nothing major. Thanks for the spotting Steve!
    I hope you get your VX fixed up without too much $$$ Sue, and I hope things like this don't deter anyone from coming out to Moab. I love hanging out with you all! Good luck Sue.
    My VehiCROSS
    May 2007
    1999 Black Rodeo
    I find it hard to believe that it bent that piece. The damage to the LCA should be much worse to bend that thick of steel. Frame straightening can be expensive but usually not as difficult as finding the right part of a frame from salvage then cutting and welding. The alignment shop probably wont know much about the way it should be. I would look for a frame shop and have someone that knows frames really well look at it to make sure exactly where you stand and what options you have.
    The front LCA mount is part of the frame so no separate parts available. Have to either straighten it or cut and weld from a donor. LCA shouldnt be too difficult to come by but can be a PITA to remove because of the rear mounting bolt. They dont like to come out sometimes.
    --Dave
    THANKS for all the input gang!
    I cleaned up both sides and took more pics at slightly different angles and views.
    I really couldn't detect any difference in angle or anything on the LCA vertical frame mount piece.
    I'm NOT real keen on chopping up my frame now that reality of this has sunk in!
    I think I agree with you guys, so I'm hoping my guy Dale can heat/hammer/BFH/weld a patch, align it, and send me on my way.
    I'll replace the LCA if needed.
    *** BOTH "CAR-PART" AND "MYPARTSHOP" SAY LCA IN '96-'97 RODEO IS THE SAME.
    DAVE DO YOU KNOW??
    THERE'S DOZENS IN PHOENIX, CAN FIND A NICE CLEAN RUST-FREE ONE***
    Anybody see anything in these pics??
    1 -
    2-
    3 -
    4 -
    5 -
    6 -PASSENGER SIDE FOR COMPARISON
    7 -
    8 -
    9 -
    10 - LOOKING STRAIGHT UP FROM GROUND AT DAMAGED A-ARM.
    CAN SEE HOW BENT INWARD IT IS - GOOD HIT FOR SURE!
    Sue, these guys are nearby and could build you some nuclear bomb proof control arms!
    Noboy said "SAS"?! Seriously?! HAHA - I would suggest replacing the LCA, getting an alignment & letting it ride! If it is too bad to get the LCA back on... heat & hammer time! Heck of a hit, Sue - STOP IT! :P
    Nov 2011
    1999 Ironman 1515
    Sue, I have to go with Zeus's comments. You drove all the way back home and your lower control arm did not fall off demonstrating the reserve capacity of the arm. The arm is cracked and that has to be addressed, if you can't find a new one beat the old one in shape and weld a section over the distressed section. If you take out part of the frame and weld in a new piece you will have a patched(weaker) frame that will lower the resale and originality plus have a good place for rust to start on the inside of the frame. Just use a stock lower control arm, if you get a beefed up one the next time the frame or something else will break. If the new arm doesn't line up, that is where the frame shop will come in.
    Mike
    Nov 2007
    1997 SILVER
    Hi Sue,
    the LCA has to be replaced, no option if you want to have a safe vehicle to drive. The fact it hasn't failed yet is okay to show reserve capacity, but the cracks and additional stress in that arm will lead to eventual failure.
    As far as the frame part goes, it does not look damaged in the photos, so I would ask your mechanic to point out the damage, and compare it to the other side.
    I would also jack the VX up and take both front wheels off. Then take photos of that frame part from outside the wheel well looking straight in.
    The force caused by the rock looks like it has gone upwards and to the rear. So the frame part could be bent to the rear and we would not see it in the photos you have taken.
    I am fairly sure a new LCA and bushes, and wheel alignment will have you happy again.
    PK
    May 2007
    1999 Black Rodeo
    Hard to see small frame member bends with the eye, really need it on a frame rack with laser alignment to check it. That said, I cant see anything that indicates any bending on the LCA mount.
    Now that myisuzuparts is gone its hard to cross reference parts. Isuzu mixed so many trooper and rodeo parts on the VX I never know which are the same. Might have to call Merlin, he should be able to tell you for sure.
  1. A note on lower ball joint / control arm bolts
    Last Post: 01/06/2014, 06:06 PM
  2. Did I damage my VX?
    By Chef in forum VX Talk...
    Last Post: 02/07/2006, 10:22 AM
  3. Damage to VX
    Last Post: 07/21/2004, 03:51 PM
  4. Taking to Dealership for repair- Need Advice
    By EclipseGSX in forum VX Troubleshooting...
    Last Post: 10/24/2003, 03:22 PM
  5. Hail damage
    By RobVX in forum VX Talk...
    Last Post: 04/07/2003, 02:02 PM
