Results 1 to 14 of 14
Thread: Torque Value for Hood Insert?
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    I've not been able to find this info with searching...
    Hood Insert has been wrapped in Carbon Fiber. Now time to reinstall however I can't find what the torque value should be for the Hood Insert Nuts.
    HELP??
    Ty
    Not sure you'll find one for these plastic fittings...but could be wrong.
    I've never torqued mine...
    ...just snug..insert sitting even...and without stressing plastic .
    All IMO only
    Jo
    Jul 2009
    Jo's got it pegged, a light touch and common sense go a long way with non-critical fasteners...torque values usually only apply to fittings with a critical torque load...
    Vixer Fixer
    Those studs aren't very strong. I use the 'Two Finger Torque' method for something like that.
    Two Finger Torque = Place thumb on head of ratchet, place pointer & bird fingers together on the handle about 2" (width of two fingers) away from the head of ratchet. Tighten till snug. Even gorilly handed fellers will have a hard time breaking a stud using that method.
    Alternate Two Finger Torque = drink plenty of two finger tequila before you get started & then you won't care that you broke the stud & can't replace it.
    BTW, Locktite is NOT recommended on those fasteners since eventually you'll prolly need to remove it again.
    Thanked: 15
    Thank you ALL! Awesome info. I'm still learning. I've been through 2 hood inserts now, this 3rd one is a new one that I had wrapped in CF w/3 coats of clear. It should be good, but I really wanted to make sure I wasn't over or under tightening the nuts. I've replaced the OEM with M6 1.0 Stainless w/stainless metric washers (forgot the exact number) and love the switch.
    I'm going to post a couple more Q's, maybe you all could help.... I'll start a new thread so that it might help someone else in the future...
    Thanks guys!
    Ty - the guy with SS stud nuts
    The only problem with that is that the washers are captive on the OEM. It could get tricky to hold the washer in place while trying to start threading the nut.
    Why so many inserts? Do they keep cracking or are you on an interitive process of them looking better-n-better?
    Thanked: 15
    lol
    The first was the original and was cracked when I first got the VX. The 2nd was due to a LIGHT front end hit, where the Weston Light Bar took the damage and nothing else was damaged... except of course a cracked hood insert. I repaired it and it lasted a while but since I am overhauling and restoring my VX, I thought a new one would be best.
    So now I'm on #3, which is new and wrapped in CF
    Thanked: 15
    I have LOTS and LOTS of pics and progress to catch everyone up with, but I will do that soon...
    for now... a sneak peak ....
    SCWEEET
    Better keep a pair of sunglasses in the VX at all times. That insert looks like a mirror.
    I hope to have my LineX'd hood insert re-installed this weekend. The one that came with my replacement hood just isn't working for me.
    Thanked: 15
    SCWEEET
    Hmmm, I hadn't thought of how it will reflect sunlight.... lol
    I'm also doing both door handles, the moon piece, the driver/passenger window switch panels, and outdoor mirrors...
    Quote Originally Posted by tysamigo View Post
    The VX sales brocheurs (SP?) indicated that's why they added the hood insert. That's why I went with LineX. Although dark & shiney, the texture keeps it from being too reflective.
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Most hoods have a shiny, gloss finish though. How was the CF applied? I love it.
    I'm assuming it's got some sort of clear coat on top? Is it built up, sanded, and redone several times?
    Jul 2009
    Whoa Ty, that looks fricken awsome, nice job! No more faded hood insert for you...X2 on the sunglasses!
    Quote Originally Posted by 89Vette View Post
    #5 says he has 3 coats of clear coat on top of the CF.
    Looks super high quality Ty!
  1. Looking for Hood Insert
    By jtirado in forum VX Talk...
    Last Post: 01/18/2016, 08:00 PM
  2. ^^^ Hood Insert ^^^
    By biju in forum VX Talk...
    Last Post: 06/20/2007, 10:59 PM
  3. OEM Hood Insert
    By VXNIT in forum VX Talk...
    Last Post: 01/14/2007, 03:14 PM
  4. VX hood insert???
    By bigdogdeee in forum VX Troubleshooting...
    Last Post: 04/13/2005, 07:57 PM
  5. Red Hood Insert?
    By totallto in forum VX Modifications...
    Last Post: 02/10/2004, 10:45 AM
