Results 1 to 14 of 14
Thread: 6ve1 or6vd1???
    Sep 2010
    1999 silver vx 0250
    6ve1 or6vd1???
    does anyone know the difference between the 6ve1 and the 6vd1 short blocks??
    i can not find a short block(6ve1)but i am able to locate several re manufactured 6vd1 short blocks
    01, LineX tan/black, 1055
    Quote Originally Posted by vxfocus View Post
    I am thinking the 6VD1 is the 3.2L as it is stamped on the bottom of my wife's 3.2l engine in the RS I spent a few hours under there while wheeling, strange I had never noticed it before and here is this post
    Jun 2010
    99, Silver, 1784
    I picked up a remanufactured 6VE1 from Barnette's a few years ago. Have a look here and click on the Isuzu icon, then scroll down to line 25. Kinda pricey, but they give a 5-year, unlimited mile warranty. To me, it was worth the expense after having not spent a dime on my rig for the few years prior.
    -VI VX VNIVERSVM VIVVS VICI-
    Sep 2010
    1999 silver vx 0250
    yikes!
    i can get a remaned long block for that price with a 4 year warranty
    just noticed that is a long block price..
    i need a short block because i allready have rebuilt heads....
    Sep 2010
    1999 silver vx 0250
    will my heads,trans,oil pump,water pump ect work with the 6vd1 3.2 block??
    Feb 2004
    '01 Ebony #0830
    I'm in the same search that you are, for my Trooper.
    I believe the 3.2 is a perfect swap. If I remember correctly, member givegodachance did it and loves it.
    It's very tempting, but only because I can't find a 6VE1 short block either!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Sep 2010
    1999 silver vx 0250
    So heads.intake.water pump.oil pump.will fit the 3.2??
    The only difference between the 98+ 3.2 and 3.5 are the pistons and the crank, the blocks are identical. The cams are slightly higher duration too if I remember right, so if you can't find the 3.5 just get a 3.2 and throw your 3.5 cams in there and call it a day. The 3.2 will only be a 5-10hp difference compared to stock so it won't really be noticable.
    Yes everything from the 3.5 will bolt right onto a 3.2 including the heads. The heads are also identical except for the camshafts which will still work on either engine, the 3.5 cams just have slightly higher duration.
    Sep 2010
    1999 silver vx 0250
    Thank you my friend
    Sep 2010
    2001 kaizer vx
    heaads, water pump, etc. are identical, will fit no problem on 3.2 6vd1
    Nov 2007
    1997 SILVER
    Not sure about USA, but here we have 2 series of the 6VD1 engine.
    Single cam was the early one, and our twin cam version was the later 1.
    The twin cam version is identical to the 3.5L engine, and has a "W" in the engine number.
    I think it is the 5th or 6th digit.
    PK
    Jul 2012
    Does the $2800 price listed with a $1000 core charge mean $3800?
    Jun 2010
    99, Silver, 1784
    No, they charge the core charge if they don't receive your swapped out motor within a certain time.
    I had nothing but good experience with them. After having been jerked around by a few other providers, they were wonderful.
    -V
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    I had talked to them and they are very helpful, but found a rebuilt one in a wreck and went with that. I live just 20 miles from them.
  1. Engine Replacement - Axiom vs. 6VE1
    Last Post: 04/10/2014, 09:34 PM
  2. My Axiom engine install 6VE1 (late)
    By Espritmike in forum VX Talk...
    Last Post: 11/18/2013, 09:10 AM
  3. The Isuzu 6VE1
    Last Post: 06/08/2010, 09:15 AM
  4. 2001 6VE1 in a 1999 VX
    By majork in forum VX Modifications...
    Last Post: 02/12/2007, 09:17 PM
