Results 1 to 5 of 5
Thread: Novice - where to buy wheel bearing hub assembly
    Jan 2011
    2000 Ironman
    I am having a difficult time trying to find a place local or online...to purchase the wheel bearing hub assembly...thanks to you for an answer...I'm stranded.
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    if looking for a used one a place in Washington state has them probably, call Thad at B&R Autowrecking, 5032852611, they have a couple and one is newer. I have got some parts from them and they are good to deal with. If looking for new call Merlin at 8007278066 and say you are from here and you get free shipping.
    Jan 2011
    2000 Ironman
    Thanks for the info...
    Is this normally such an expensive part...? thanks again, Renee
    I've been told that the ones you get from Isuzu are very high quality bearings and that if you buy Cheapo Knock-Offs that you may get very low quality steel bearings. That's just what I've heard ... I can't validate that.
    What I can tell you from experience is that when I ordered some Cheapo Knock-Offs, I only got the caged bearings & no inner or outer races. I never used them since I'd never replace the bearings without the races. Unfortunately the advertisements never give you enough detail to determine if you are getting a complete set of bearings.
    Jan 2011
    2000 Ironman
    Thanks...I went ahead and ordered the higher end ones..
    Perhaps we won't have to go down this road again...it's been quite a journey!...thanks for your help.
  1. How Much For Wheel Bearing Replacement?
    By bartmanS4 in forum VX Talk...
    Last Post: 03/25/2014, 02:58 PM
  2. Help with bearing cover behind wheel
    By Mrmonk7663 in forum VX Troubleshooting...
    Last Post: 05/17/2010, 10:17 AM
  3. does this sound like a wheel bearing?
    By spitfire5454 in forum VX Troubleshooting...
    Last Post: 09/26/2008, 10:47 PM
  4. wheel bearing seal broken?
    By xiaoz in forum VX Troubleshooting...
    Last Post: 03/04/2008, 05:47 PM
  5. Another Wheel Bearing story (and a tip or two)
    By kinnaq in forum VX Troubleshooting...
    Last Post: 07/19/2007, 12:32 PM
