OF COURSE THE AXLE WOULD NOT SLIDE OUT!!!!! Do not let a shop work on your rear axles they will ruin your ABS sensor and charge you to replace it! ABS sensor MUST BE REMOVED to remove rear axle. I guarantee you they did not know this and if they put a gear puller on it they probably already ruined your ABS speed sensor. Good luck.
