I'm having trouble diagnosing a 4L and 4H problem with the front two wheels not engaging. A hobby mechanic told me it was the front differential but he doesn't know VX. I seek the pro's.
SYMPTOMS
4L- loud popping in irregular frequency coming from the front end. Wheels don't turn
4H- lighter sounding popping in the front. When AWD puts more torque up there the popping is as loud as 4L. When getting to speeds around thirty, I hear a jingle up there which sounds like a couple of BBs in a tin can shaken quickly.
No increase noise in turns
MODIFICATIONS
Calmini lift and some aftermarket rims and hub covers
WHAT I DID
Changed out the transfer case fluid which looked horrible and tonight ill do the front and rear differential fluids. I'd hear of putting a small magnet in the case, looking for metal shavings so ill give that a try too. Currently, the tires are size 32 inch and I am feeling like new gears would be helpful to keep the engine running in its designed power margin. If the front differential is the problem, should I purchase new gears instead of replacing the pumkin gear in the size I don't want? Thanks for your time if you reply. Ill also take as many pictures as I can to help out others as much as possible.
