I am still overheating and I am now wondering if it is a bad fan clutch.
I have replaced, thermostat, water pump, timing belt, and intake gaskets, hoping that would cure the problem. I did have an intake gasket leak.
Any solid way to test the fan clutch or fan speed?
... and turn the fan by hand. If the fan clutch is working properly, it should be tough to turn.
