Results 76 to 85 of 85
Thread: Replacement Axle Assemblies from SurTrack.....
Threaded View
    From the research and hands on checking I've been able to do...
    ...it looks to me like the SurTrack Axle assemblies are the best bet
    replacement for our OEM ones.
    [EDIT...ADDED AFTER "TESTING"....
    ...not recommended for hard off roading...GREAT for normal road use and light trails
    Thye have the same Ball race configuration in the 'Green Cup" as
    OEM does .... NOT the tripod that causes issues when lifted.
    The ball bearings are the same size as OEM, not small as per "Empi" brand...
    ...so no binding issues.
    IMO, this also means that part assemblies will fit rather than the need for full
    replacement if not required.
    Shaft diameter is the only "iffy" spec...
    I measured two OEM shafts, and got 27.2mm in one, and 28mm in the other...??
    The SurTrack clocked in at 27.5mm.
    SurTrack told me that the axle size does vary a bit depending on 'raw' material supplier.
    However...spline diam and spline count were the same...so shouldnt be an issue.
    I have ordered a complete driver/pass side set to be shipped to me and I'll bring
    them to Moab for general inspection/once over.
    They also sell outer only assemblies (Part# IZ-8021..same for both sides)
    If you want to go ahead and order your own, contact :-
    DEAN @ ONE STOP (tell him you are a VX.info club member !)
    Tel:- 1-760-598-4852
    Pass side ( short side).......... Part # IZ-8010...........$88:00 + tax
    Driver side ( long side).......... Part # IZ-8011...........$88:00 + tax
    ** Update**
    Half shaft option from Amazon or other Stockists..
    ...for those not requiring full replacement.
    SurTrack IZ-8021 CV Axle Shaft for $50 each of Amazon.
    Shipping varies depending on Location ( charged me only $15;00).....
    ....he will ship direct to you....normally they only ship to garages/trade outlets.
    Hope this helps.
    Jo
  1. CV Axle replacement
    By VehiTONY in forum VX Troubleshooting...
    Last Post: 04/14/2014, 03:32 PM
  2. Sur Track CV axle replacement.
    By whitebreadx in forum VX Talk...
    Last Post: 10/17/2013, 03:56 PM
  3. Axle Assemblies....Anyone heard of SURTRACK?
    Last Post: 03/26/2013, 12:53 PM
  4. cv axle replacement
    By ramathorn in forum VX Troubleshooting...
    Last Post: 09/25/2012, 07:20 AM
  5. Changing CV joints (front right and left axle assemblies)
    By mcaramb in forum VX Troubleshooting...
    Last Post: 04/11/2012, 04:54 PM
