Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Need help vx won't turn over
    Apr 2011
    99 Ebony, VX, #2007
    Makes sence but why would disconnecting the battery work once but 30 mins later it not want to start again. It does sound like the starter relay is clicking but normally a bad connection or a weak battery will still lead to some noise from the starter. The earlier start sounded as strong as ever which also leads me away from a bad battery connection. At this point it's looking like I will have to get a tow. But knowing my luck it will start once in the morning and leave me stranded somewhere else
    Apr 2011
    99 Ebony, VX, #2007
    Unhappy
    Well after trying to jump the truck thinking the 14.5 volts might help push past any corrosion in the cable I'm out of ideas and am getting it towed to a better location my garage.
    Aug 2012
    99 Ebony Vx's, 0054 & 1548
    just thinking and typing....
    steering column switch? it controls the lock pin on the column. If it is not locking, it might not let the vx start. The Ignition lock switch (right) plugs into the Ignition switch control (left side in column) and it has wiring plug on it.
    trying to help....
    I haven't had any simular problems with the vx
    Life is better when you go Topless
    Apr 2011
    99 Ebony, VX, #2007
    Well I got the wheel to lock. I had to turn it 1.5 turns but it locked. It's home now the toe truck driver managed to back it right into the garage so further application of the bfh can be done out of the cold
    '01 Ebony #0939
    You might try removing and reseating the Starter Relay and the Starter Cut Relay in the engine bay fuse box. Have you noticed any erratic illumination of the gear position indicator lights on your dash as this has been happening?
    Apr 2011
    99 Ebony, VX, #2007
    Nothing weird on the dash while attempting to start. Only weird light display is on the fifth turn from off to run. I get a loud beep from out side the truck and all the lights on the dash flash once
    Apr 2011
    99 Ebony, VX, #2007
    Ok so small update, it is not the the security system or the park neutral switch. The starter relay itself is activating but havering no affect on the start. So nw Saturday after work I have to jump the selonoid to rule out a bad starter if that's good I'll have to trace wires.
    Apr 2011
    99 Ebony, VX, #2007
    So finally figured it out. After making a small modification to the inner fender so I could get to the starter. All it took was a wiggle of the signal wire connector to the starter and she fired up. My guess is that it shook loose now all I have to do is secure it and hope it doesn't come loose on the trail this weekend
  1. wipers do not turn off
    By disasterlady in forum VX Troubleshooting...
    Last Post: 11/11/2016, 07:16 AM
  2. Now it's my turn....
    By Gussie2000 in forum VX Troubleshooting...
    Last Post: 01/26/2012, 07:11 PM
  3. Key won't go into ignition or turn
    By kobie in forum VX Troubleshooting...
    Last Post: 06/29/2010, 10:41 PM
  4. Now it won't turn over
    By DK in forum VX Troubleshooting...
    Last Post: 05/16/2005, 10:11 PM
  5. turn off TOD?
    By marximus in forum VX Talk...
    Last Post: 12/31/2004, 05:33 AM
