Before you say I should just drive it. take a look at the photo. I move from the North in November and then back in May or June. I take all my toys with me. Previously I had a Mini Cooper that fit in the box on the truck. Now it's the travel spot for the VX. Last weekend I test fit it in a similar truck whose owner drives a "Tracker" and has 10 foot ramps for his truck. Since the Mini was so low to the ground I would have to search out a loading dock to load and unload. (Or pay a tow company $100 to use their ramp truck.
Anyway, I have the tire straps that I used for the Mini. (No frame or axles to tie from). I plan to check the fit and use them too but will want to tie down from the frame, axle's or tow hooks. I have built a wheel/tire chock that will provide a secure stop from forward motion on one corner and the other three wheels will be tied down with opposing frame, axle or tow hook straps. What do you think? Overkill or not enough?
Rod
