Results 16 to 30 of 45
Thread: Rear bump stops -- optional or necessary?
    Quote Originally Posted by blacksambo View Post
    your hard cornering roll resistance will suffer as these crazy rubber eights are termed spring helpers by Isuzu. Cut them at your own peril.
    I don't think the rear bumpstops serve any function other than to keep the tires from contacting the body.
    Yeh...def 2 schools of thought on that subject...
    I use mine to keep the tires from getting "over stuffed" all up in dat fender well thang...
    I hafta agree with Dub & Swede (Did I REALLY just say that out loud???).
    It doesn't matter what you call those rubber donuts. It doesn't matter what Isuzu calls them. They serve the sole purpose of STOPPING suspension travel (in a bone jarring, blood pissing manner). If they are engaging whilst driving on road, you have something wrong with your suspension (design defect or worn parts). They should NOT play a part in helping with on road body roll.
    If you only have a fraction of an inch of distance between the bump stop & the axle housing ... & you don't want to cut the stop, then you should be seriously considering replacement coils (either OEM or aftermarket). Coil springs do have a tendancy to sag with time & use (lets see, I'll set 1000 lbs on this here coil spring & let it sit for 13 years ... I wonder if the spring will deform???)
    Or better yet - do like Mav did & add an airbag inside the coil ... infinitely adjustable & air makes a nice cushy ride!!!
    No need to argue about this subject anymore IMHO. Cut your stops in half to stop the jarring ride then install an Air Lift system to stiffen your springs and reduce body roll. You can cut the stops and install the Air Lift system in your garage and the kit costs $130. That's cheaper than new shocks, coil spacers, or new coils. Everybody wins!
    http://www.vehicross.info/forums/showthread.php?t=22408
    http://shop.airliftcompany.com/produ...g_Leveling_Kit
    Mav,
    Since you're the guinea pig on air suspension upgrade at the moment: What pressure do you run on yours?
    Oct 2012
    2001, Proton, 0586
    You need to keep in mind that rubber isolators and springs are used in numerous applications!
    Its main advantages are:
    - High stiffness with relatively small size (not important or desirable on VX suspension, but great for motor mounts)
    - Inherent damping, that is missing in metal springs (again, great for motor mounts, but shocks provide plenty of damping in suspension)
    Its downside is:
    - Deterioration over time (rubber gets harder/stiffer with age, until it cracks and becomes much softer)
    - Varying performance (stiffness/damping) depending on ambient temperature (that should make our suspension MUCH stiffer in the winter)
    Looking at our spring helper design, this is NOT your typical "bump stop"! It is designed to be relatively soft and to have a relatively long displacement!
    But overall, rubber is NOT an ideal material for vehicle springs, especially for a varying climate vehicle with a considerable suspension travel. I am sure that Isuzu engineers were well aware of the above information. So why would they add this inferior component to their flagship vehicle?
    Lets look at vehicle dynamics, why would you stiffen rear end? This isn't a tow vehicle and stock springs seem to be stiff enough own their own for normal driving. The only reason I can see is to make it safer during emergency maneuvers. Stiffer rear suspension also keeps the front end straight, reducing "plowing" effect in hard cornering. The downside is that you pay for it diminished rear end traction (especially when you hit bumps, right 89vette? ). But apparently, they were willing to live with it.
    I suspect that they determined that they need more rear end stiffness, which could have been achieved by stiffer shocks, springs or rear sway bars. But some bean counter probably insisted on adding an additional section to an existing suspension bump stop, thus turning it into a "spring helper". In most cases, this is a cheaper solution.
    This would also explain if people feel these "helpers" and complain about them more often in the winter months .
    So while this was not a good solution, it was a solution to a problem that I am not sure many of us would want to experience...
    My VX still has the helpers and it has been practically bumpy in the rear end, as of late . I am still not sure if want to cut them. I might remove them all together to test out the handling. This way, it will be reversible. Another solution might be to get new OEM helpers, if the original became too stiff.
    Aug 2005
    1999, silver, 0887
    Quote Originally Posted by Leon R View Post
    Its downside is:
    Well put. Great analysis.
    Between this inexpensive suspension solution and the genetic-weakling transmission we have, I keep coming to the conclusion that the VX was more styling and novel mechanics oriented than a serious performance vehicle. I think it looked so tough everybody thought it would perform the same way......it was more of a way ahead of it's time science-fiction project. It was a brave endeavor, and I still love mine for it being so.
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Between this inexpensive suspension solution...
    Lots of vehicles have these types of travel limiters. Unless I see a link to something showing Isuzu really considered this an "active" part if the suspension, I think you're stretching to make the assumptions you're making.
    I totally agree with your assessment on analysis though!
    Aug 2005
    1999, silver, 0887
    Quote Originally Posted by 89Vette View Post
    All you have to do is look at the cut-away drawings on the VX JDM brochure to see that the spring helper basically rides on the rear axel to know it had to be an active part of the suspension that was intended curbed body roll.
    Feb 2010
    Thanked: 19
    Is there an online link? In the "Rear Suspension" diagram of this link we don't even see the stops pictured. That tells me they're not considered an active part of the suspension.
    Mar 2012
    sold
    the nipples to air up and deflate the bags on my chevy truck are next to the license plate where did you put yours?
    I had the lines run into a "T" connector so there's only one valve. The new tom4bren bumper doesn't have holes for two of the bottom cladding screws so my valve is mounted vertically facing downward (outward) through one of those holes. Can't even see it unless you kneel down.
    If I were to put them on the VX, I think I'd have the valve in the jack storage compartment.
    Wrench
    FWIW...
    If you install a "T" fitting, as opposed to two individual nipples, you are increasing body roll.
    When one side compresses, it sends pressure over to the other side, increasing pressure...
    Which will magnify body roll.
    Nov 2011
    1999 Ironman 1515
    Has anyone tried replacing the rear spring with an air bag?
    Mike
    Hmmm... good point Dub. Might have to split that line at some point then.
  1. rear bump stops
    By vxfocus in forum VX Modifications...
    Last Post: 10/13/2012, 09:59 AM
  2. Bump stops
    Last Post: 09/13/2012, 04:29 PM
  3. Bump Stops (again)
    Last Post: 03/03/2011, 03:00 PM
  4. Bump Stops
    By JAMAS in forum VX Talk...
    Last Post: 04/15/2009, 07:02 PM
  5. Rear Bump-stops
    By kelvin in forum VX Troubleshooting...
    Last Post: 05/31/2007, 03:23 PM
