Went for a haircut and she wouldn't start afterwards. Appears to be a fuel pump issue. I don't hear the pump at all and I pulled the line going to the filter and had someone crank her over - no joy. Fuse OK and I swapped the relay with the starter relay - nope. I jumpered out the relay connector pin according to the manual - negative. I am going to have a buddy tow me in the AM, I just hope it doesn't get towed in the meantime. I am considering cutting an access hole trough the rear floor, I saw that JPuga87's ride had this done but from the pictures it looks like the wrong spot. Thoughts?
http://www.vehicross.info/forums/sho...8&postcount=19
