What does this cluster go to?
Link of quick video to show what I'm talking about.
http://www.youtube.com/watch?v=I8BYOwzpls0
can you post some pix? I can't view youtube whilst at work.
scanner plug?
That is where you connect a scanner. It should be tucked away in a mount under the dash closest to the door.
If you have a copy of the shop manual, look on page 6E-33 (pdf page 12603) for a drawing of the connector. Page 6E-35 (pdf page 12605) shows the location in the cab.
Yep, that's the OBDII connector. It's used by a code reader, or diagnostic equipment, to read the computer and any trouble codes that may be stored. It actually clips into the little bracket with the hole in it right above the connector in your picture.
Here's a picture of mine with the ScanGaugeII plugged into it (with the lower dashboard piece removed).
That's pretty sweet. You turned your OBDII around so the cable from your ScanGuage runs the opposite direction???
Did you also install a biometric lock mechanism in your door jam??? That's a pretty impressive thumbprint ya got there son!!!
We all know its really for a breathalyzer. We know how you are Mark.
--Dave
I used to have my flux capacitor hooked up to mine.![]()
It's the preamble to "black box" technology. The feds some day will know EVERYTHING about you even the movement and whereabouts of your car.!!!!
Oh sir we see you stops at Buds gun shop yesterday and according to our merchant records you purchased 800 rounds of 50 caliber ammo....What were you planning on using it for. Hmmm. And who do you think you are driving this archaic ungreen Isuzu. And you bought a Dominoes pizza we really would prefer you purchase Pizza Hut from now on...Do you understand!!!
