I know that when our pistons are not firing they act as sensors.
I was wondering if iridium tip spark plugs would throw misfire codes ( blinking CEL)? My MR-2 spyder uses iridium tipped plugs and the manual says that the only kind I can use in it, It has a simular spark plug sensing set up. I was also wondering if the iridium tips would give better performance?![]()
