Results 1 to 4 of 4
Thread: rear defrost
    Apr 2012
    1999 silver 1685
    rear defrost
    Does anyone know if there is a way to fix the lines of the defroster on the back window? From the bottom the third and forth dont work. And as you all know we need as much rear view as possible.
    Can you see where the lines have been damaged?
    I've seen kits for repairing them at autozone or advanced auto parts. Pretty simple it looks like clear tape with a strip of conductor running through it
    Nov 2011
    1999 Silver VX #0758
    I used a kit from Autozone once but I think I had to solder the broken wires on the glass. If you can find the break in the conductor you should be able to fix it. If your window is tinted that will make it more difficult to repair.
  1. Front and rear (rear) driveshaft joints are different?
    By 89Vette in forum VX Troubleshooting...
    Last Post: 10/05/2013, 09:02 PM
