Well I did some great snow boggin last weekend, but had a chunk of ice fly up and break my radiator shoroud. Not worried about the airflow from the shroud because it's cool enough here in Alaska to not worry about it. Unfortunately, the broken shroud went up into the fan and broke off half of two of the fan bladesSo now I need to replace the fan (obviously) and can not find a good replacement anywhere. Before anyone suggests swinging to an electric....I may do that this summer, but right now I want to just do the regular fan replacement. It's extremely cold here now and I'm not about to go through the hassle of doing the electric mod right now. One of the blades on the old fan managed to cut the wires to what I am guessing is a oil sensor on the backside of where the oil filter is located. Anywho...anyone know any good aftermarket fans that will bolt on to the OEM fan clutch?
