Do you think these would work in the projectors i have on my VX?
Honestly, now that I've done it a few times, it takes like 5 mins, tops. Grille comes out (2 10mm bolts on top and 2/3 screws in the grille face, can't remember exactly), then you take off the cladding screws, and including the screws in the wheel wells and the 3 underneath. Slides right off after that.
Well, I know I'm not alone when it comes to tinkering and things not going as intended. The Alltech pros cracked the interior covering left of the brake pedal when replacing the flasher. They pointed out the damage and advised they would replace it at no charge. Don't know specifically how it got cracked. Seems out of the way from what they were working on.![]()
Ordered 4 of these
http://www.amazon.com/dp/B00AIJY2ZM/..._26725410_item
Already have HD PIAA fogs in the grill, will see how these add to the equation ^__^
- To Err Is Human, To GET SOME is Divine -
those are mostly like 194 bulbs, which will fit in your
upper Horn parts of the headlight and or front corner
fender light too, or your license plate bulbs.
I actually sell those for like $7 each just fyi..
but their price isnt too bad.
Check out our VX accessories @
www.planetsvx.com
click on the Vehicross button on the left side
of the page
I'm happy with these. I like that the LEDs are sealed in bulbs. I installed them in the side markers, fender "horns" and front parking lights. They are intensely bright and clearly visible in daylight. Had the fender horn lights and front parking lights wired to an independent fog light switch, which I use as DRLs.
