Results 46 to 59 of 59
Thread: Marvel Mystery Oil
    Sleeping on an issue sometimes brings clarity...I recall this morning something my dad did to free sticky rings in our '64 Comet with great results. It was burning oil and he knew it was getting past the rings 'cuz it even smoked a little after warm-up, so one Friday night after mom got home he pulled the plugs and poured Marvel Mystery Oil in each cylinder and then turned the engine over a few times by hand and shut the hood 'till Sunday afternoon. He reinstalled the plugs and fired it up, let it build oil pressure and then reved the hell out of it; man did that thing smoke! After about five minutes of idling and occasional reving he took it out with me and "burned the carbon out". No more smoking Comet, the MMO freed-up the rings and they did their job for the next couple of years until my older brother got the car and proceeded to wreck it much to our father's dismay...Now, would that trick work on our oft-times fouled-ringed little V6's? Can't see how it could hurt to try, it dissolved whatever gunk was sticking the rings in that old Ford. In hindsight, and with what I've learned since all those years ago, I'm sure the ring-lands were carboned-up and the Marvel dissolved that carbon. Sounds like a familiar situation, hmmmmmmm... Anybody care to give it a shot?
    I did the same thing on a Chevy V8 with transmission fluid in the carb to clean the top end...run the engine...pour it in....shut it off and let sit overnight...start it up the next day and no bugs for about 2 months from the smoke...
    Aug 2005
    1999, silver, 0887
    Correct me if I'm wrong but aren't we kinda doing that by blowing Marvel Mystery treated Crankcase oil into the plenum via the PCV?
    Aug 2005
    1999, silver, 0887
    Also, you can add Marvel Mystery to your gas and get it into the top of the engine, can't ya?
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Via PCV or Fuel, It wouldn't have time to "penetrate" the rings. IMO, not the same.
    OTOH, I'd have to think a higher concentration of Naptha via "Motor Flush" would be "the same" as an over-night soak.
    IIRC, they say you can go a few days/100 miles with light driving....Can't remember for sure. Haven't used the stuff since the 70's.
    Wrench
    Quote Originally Posted by 89Vette View Post
    I'd have to agree, since the oil ring is in the bottom groove of the piston, the only time it'll have a chance to see any sea foam, or mmo, would be if added to the crank case.
    Aug 2005
    1999, silver, 0887
    Good point. Thx
    Sep 2014
    2001, Foxfire Red, 1283
    Maybe that's the Mystery? I've used it since the 80's and it's great stuff. Wouldn't put too much in the gas tank, after all, it is oil. Good for the valves and older engines.
    Jun 2007
    2001, Proton
    It may say oil in the name
    Quote Originally Posted by Cable Bob View Post
    But it is most definately not oil.
    Carter Pewterschmidt
    Jul 2009
    I use MMO in my nitro vehicles as an after-run oil as it keeps the castor oil from gumming up the works and protects against corrosion, but then so does WD-40. It does have lubricating qualities to it but I wouldn't use it as a primary lubricant, that is to say as a the only lubricant in an engine. I am a firm believer in it's ability to free stickey rings when poured into the cylinders and left to sit for a few days.
    Vixer Fixer
    Sep 2014
    When you pour too much in your gas tank it will burn off like oil, blue smoke out the exhaust. I ran it in an old Case Mini Sneaker and it kept it alive beyond it's normal shelf life, it kept the valves from sticking and kept the compression up.
    "The product is composed of 74 percent mineral oil, 25 percent stoddard solvent, and 1 percent lard."
    74% Mineral Oil is Oil, may not be motor oil but it is oil.
    Jun 2007
    2001, Proton
    OK technically
    you are right.
  1. EGR Mystery
    Last Post: 02/25/2015, 10:33 AM
  2. Interesting VX Mystery?
    Last Post: 03/09/2005, 12:01 PM
  3. Mystery Bolt...
    By Navigator in forum VX Talk...
    Last Post: 02/17/2005, 03:25 PM
  4. CD Changer Mystery ???????
    Last Post: 08/19/2004, 10:32 AM
  5. Marvel Mystery Oil
    By tomdietrying in forum VX Talk...
    Last Post: 04/21/2003, 08:18 PM
