Results 1 to 15 of 18
Thread: Replacing AC Compressor - Help
    Jan 2013
    01,grey,vehicross,5600
    hi, is it possible to remove clutch and bearing right from vehicle ?? thats what i am trying to do, but those(loan tools) seams like doesnt fit 01 model.
    ii got my own bolts to fit clutch plate, but still something holding it... Any suggestions ? thank you
    i got bad bearing, ,,, what did you use to remove clutch? did u puled it out with 3 bolts and one on middle?
    also is there a snap ring needed to be removed to pul pulley ??? thanks for your help ... i regret the day i bbought VX too :-) , it was all good when it was new, now its like falling a part, one part at a time... i got temp replacement- Explorer 94 with 200k miles,, guess what?? no problem and easy to access any bolts
    Feb 2004
    '01 Ebony #0830
    Question
    Reactivating this thread because I need the same answer as the last post.
    Can the compressor's clutch/pulley be removed with the compressor still mounted to the engine?
    If not, do I HAVE to remove the lines, or am I just screwed all the way around and have to pull the compressor completely out?
    Thanks for any help!
    JIM
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Jun 2007
    2001, Proton
    Replacing the A?C Compressor sux
    It's probably easier to install rather than find. Tons of them are on ebay but they will list just any part with any car to make the sale.
    Carter Pewterschmidt
    01, LineX tan/black, 1055
    Hmmm, I pulled mine out of the wheel well, no problems or special tools needed. It was tight, but it fit, didn't even take the wheel off, and mine definitely came off of an 02 trooper. It was a tiny bit longer(fore to aft), but no problems with fit.
  1. Cost (with labor) for replacing the AC compressor?
    By TenPercenter in forum VX Troubleshooting...
    Last Post: 09/08/2015, 10:59 AM
  2. a/c compressor
    Last Post: 06/16/2012, 10:26 AM
  3. Replacing the Bearing in the AC Compressor.
    By O Hell No O in forum VX Troubleshooting...
    Last Post: 08/02/2011, 11:25 AM
  4. Compressor or Jumpre/Compressor?
    By RabidPony in forum VX Talk...
    Last Post: 08/10/2010, 12:41 PM
  5. A/C compressor fan
    Last Post: 04/07/2010, 05:18 AM
