Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: VX Electrical Poltergeist caught on video
  1. #16
    '01 Ebony #0939
    Quote Originally Posted by BOARZHEAD View Post
    When i had my 1999 vx had simular problems. Main wire harness on driverside behind headlight was mounted to radiator support from factory with a pointed screw behind it. It worked its way into harness and would ground wires. If yours is 1999 look there. My 2000 the screw and harness are not near each other. I will post pic of what i mean. My truck would buck and try to die then nothing for weeks. Found this by accident when truck was running i had my hands around harness and it did it. Had to pull harness out alittle and re heatshrink wires then was fixed
    Now that you mention it, that culprit does sound very similar to another thread years ago where similar symptoms were listed. It seems like in that past case, it was the wire harnesses' routing near a piece of framework in the area of the headlight that caused the framework itself to start wearing through the insulation on some of the wiring, but the result was the same. Missing insulation on a group of wires run in the same bundle could absolutely cause a multitude of problems that wouldn't normally be related in individual circuits.
  2. #17
    Feb 2004
    '01 Ebony #0830
    Update...
    I checked the wiring harness in the headlight area. No damage. Wasn't able to get it to fail while the engine was running. In fact, the harness was almost hard as rock.
    I did find two possible culprits though...
    1. Both battery terminals had a thin film of corrosion at the mating surfaces.
    ... Cleaned and tightened.
    2. Replaced my stereo (Christmas present! Click here to see!)
    ...Cleaned up wiring. Moved head unit to lower position where the CD changer used to be. Mounted iPhones (x2) to top location.
    Found exposed hot wire dangling!
    Removed during re-wire.
    Issue has not returned...
    To be continued.
    Thank you for all assistance!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
  3. #18
    May 2003
    2000 Ebony VX 0577
    Good luck. hope that its solved...
    I always take life with a grain of salt. Plus mashed potatoes and gravy!
  1. Zero electrical power?
    By blacksambo in forum VX Troubleshooting...
    Last Post: 04/22/2014, 02:14 PM
  2. to the electrical guys..
    Last Post: 09/25/2008, 07:55 PM
  3. electrical question.....
    By dynofan in forum VX Talk...
    Last Post: 06/08/2006, 07:29 PM
  4. Dead VX, Seems Electrical
    By jbregar in forum VX Troubleshooting...
    Last Post: 09/20/2004, 11:04 AM
  5. Electrical Problems...
    By Jolly Roger VX'er in forum VX Talk...
    Last Post: 08/18/2003, 02:32 PM
