Hello everyone,
So I need help with replacing my front and rear Brake lines. I have attached a photo of the fronts... I have the brake line 10mm wrench that Rickshaw said you had to get. And I can disconnect the nut from the line. But the line is still locked in place.. My question now is How do I remove the OEM lines? Is there a clip holding it in place? And if so, can someone tell me how to get it off and where it is?
Thank you so much, I know this shouldn't be hard but i'm stumped right now. Putting on the new brake lines isn't the issue, its just removing the old ones.
Any help is greatly appreciated.
