Hoping someone can help. My wonderful VA state inspection a few weeks ago didn't uncover my rear brakes were worn. Yesterday I was metal to metal. I decided to try and tackle this on my own. Bought the pads and rotors and started getting busy. I didn't compress the piston far enough before I took it apart and now I'm stuck. I have enough room for both pads, but not enough to fit over the rotor. I can't seem to get the piston to compress any more. Anyone have any suggestions? I guess draining the brake fluid will reduce the pressure? I'm trying to avoid bleeding the brakes, but I guess it wouldn't hurt to replace the fluid too since I'm learning new things here and seeing I've only had "Jack" a month or so, who knows when it was done.
