Has anybody ever seen or heard of an EZ TOW trailer?
~The hole deal weighs 344 lbs, with towing capacity of 1,000 lbs.
~It's just a polypropylene plastic box with a wood floor.
~Can add a tongue box and can get a jockey wheel as option, but I can't imagine needing it to move it.
~I'd have maybe 200 pounds cargo, so 544 lbs...VX would handle that w/o a sweat.
~ANY INPUT/IMPRESSIONS OF IT IS MOST WANTED
WEBSITE: (SUPER CLUTTERED!)
http://www.bestbuydealer.com/EZTOW/E...OME%20PAGE.htm
EBAY:http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466
THE PITCH:
- THE EZ TOW IS THE # 1 SELLING ROTO MOLDED TRAILER IN THE WORLD.
- The EZ Tow Trailer is the most stylish and affordable scooter trailer on the market. It is big enough to load large electric scooters and powerchairs.
- It comes standard with EZ Lube hub wheels. This type of hub alone can save you hundreds of dollars over the life of the trailer.
- The torsion flex 2200 lb axle mounted to the under side of the frame and along with the 12" wheels provides a very smooth ride on even the roughest roads.
- The EZ Tow Trailer attaches to any hitch and can be easily towed along by the smallest of cars and can carry up to 1000 lbs.
- The EZ Tow comes in 9 great colors - red, orange, black, yellow, grey, dark green, lime green, royal blue, Mary Kay pink ....hehe
EZ Tow Enclosed Trailer Technical Specifications- Outside Dimensions: 6' Long x 4' Wide x 4' Height
- Inside Dimensions: 6' Long x 4' Wide (1" less than the outside measurements)
- Rear Door Size: Large 46" x 46" Opening
- Rear Door Weight Capacity: 400 lbs.
- Ceiling Height: Front 43", Rear Opening 50"
- Load Capacity: 1000 lbs.
- Class Hitch Compatibility: I, II, or III class hitch
