Help.....I was sitting at a stop when the engine shut completely off. It turned over but would not restart like it was not getting fuel. O towed it home and threw a fuel pressure tester on the fuel rail and with the key on I had zero pressure. I jumped the fuel pump relay and had then had 48 lbs of pressure. Its seems the fuel pump is working. I also noticed the fuel gauge reads below empty with no movement when I turn on the key, (i have 1/2 tank of fuel), also no check engine light with the key on. No fuel pressure when I attempt to start it. Fuel pressure when I jump the relay, no fuel gauge and no check engine light. Prior to this no problems, I'm stumped.
