Results 1 to 15 of 21
Thread: Engineering help needed
    Quote Originally Posted by Cobrajet View Post
    Still open to ideas, but this may give you some idea what I am trying to accomplish. I'm sure Tom will come up with some ingenious device that will revolutionize rotisserie grilling as we know it.
    Actually, I was thinking about developing a PTO from the VX that could provide the input to a hydraulic pump which in turn would feed the venturi of the drive mechanism of a stator mounted rotational effector within the ether containment enclosure of said convection coloric dispersement device.
    I was thinking the same thing until I factored in the cumulative parasitic losses associated with a multiple-interface, redundant convective pulse drive in combination with a stationary inverse wave reducer to obviate the oscillations inherent in the horizontal bi-polar twin-screw spindle.
    Gregg
    2001 Proton Yellow #1379
    The parasitic losses associated with a multiple-interface, redundant convective pulse drive are mitigated by obviating the vibrational component via structural stiffening.
    The stationary inverse wave reducer to obviate the oscillations inherent in the horizontal bi-polar twin-screw spindle issue is de-facto eliminated by the inherent autonomous dampening of the hydraulic drive mechanism.
    DAYUM son ... one or both of us really gotta get a life.
    May 2012
    2001 Iron Man,Vehicross,0814
    Yes but I think you both overlooked the the obvious potential of a photon drive principal coupled with the advantages of inherent reverse osmosis factored into the equation. However this could be overlooked by factoring in a mass damper to offset the effect of parametric deviations.
    Quote Originally Posted by Maddawg View Post
    Yes but I think you both overlooked the the obvious potential of a photon drive principal coupled with the advantages of inherent reverse osmosis factoring in the equation.
    Considered & rejected.
    Photon drive principal is only theoretically effective in the vacuum of space.
    Reverse osmosis will only be effective if somebody pisses on CobraJet's charcoal ... & we can't have none of that.
    May 2012
    Sez you. That's the prescribed manner in which I douse my coals.
  1. Proton in "Stay With It" Engineering campaign
    By Baldwin in forum VX Talk...
    Last Post: 03/19/2013, 09:11 PM
  2. help needed
    Last Post: 07/07/2012, 04:19 PM
  3. Help needed
    By Grok in forum VX Talk...
    Last Post: 01/10/2011, 12:42 PM
  4. Help needed.
    By igor_san in forum VX Modifications...
    Last Post: 08/11/2009, 08:25 AM
  5. Help is needed
    Last Post: 01/25/2007, 04:44 PM
