Results 1 to 15 of 21
Thread: Engineering help needed
Threaded View
  1. #6
    What's the cross section dimension of the square shaft?
    I was think'n something like this...in stainless, of course...
    It's a standard 5/16" square rod. Your idea is ideal, however, I don't happen to have any of those in my junk box.
    Kinda hard to tell if the "threaded weight" is supposed to attach to the bottom of the silver/chrome cylinder (with loop) or what.
    Clamp sounds like a reasonable option
    Obviously drilling/tapping with a stud is an option.
    I'll also tell you that I've found (and used) a 2000-deg adhesive in the past. You could fill the cylinder if it's suppose to wrap around that square peg.
    http://www.cotronics.com/vo/cotr/newprod.htm
    The "threaded weight" is not a weight. but more of a threaded "stop" to be used with a screw-on handle found on many spits. My rod is not threaded, so I can't use that part. I do have a set of dies, but my rod end sits in a cradle, so attaching the counter weight to the end is not an option. It has to be inside the grill, close to the bird. I do need some kind of clamping hardware, but what and where. I have some ideas I will try to post later.
    Quote Originally Posted by Maddawg View Post
    Why do you need the counter-weight at all??????
    Turkeys are very hard to balance, and also tend to move around during cooking. My last two attempts have resulted in stripped gears and/or failed motors leading to brurnt turkey! Not good.
    Just run a Google image search for "rotisserie" and "counterweight" and you'll surely find enough visual examples to figure out how you can utilize the pieces you have.
    I did that and found no one using this style counterweight without the screw-on handle mount. I need to improvise.
  1. Proton in "Stay With It" Engineering campaign
    By Baldwin in forum VX Talk...
    Last Post: 03/19/2013, 09:11 PM
  2. help needed
    Last Post: 07/07/2012, 04:19 PM
  3. Help needed
    By Grok in forum VX Talk...
    Last Post: 01/10/2011, 12:42 PM
  4. Help needed.
    By igor_san in forum VX Modifications...
    Last Post: 08/11/2009, 08:25 AM
  5. Help is needed
    Last Post: 01/25/2007, 04:44 PM
