Results 1 to 8 of 8
Thread: Turn signal on when braking??
    Feb 2004
    '01 Ebony #0830
    I do have trailer wiring, but haven't used it in about a year. I'll check into it. Thanks!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Yah, when mine started acting up, I hadn't used it in a while either. Unfortunately, I was in the process of wiring in the replacement when I found the loose ground wire.
    Agree with Tom. Also are you using standard bulbs or LED bulbs? I have seen many people have issues with LED bulbs in the tail/turn signals. Sometimes you need load resistors across the brake lights in addition to turn signals. try using that turn signal when you are on the highway with cruise control engaged. If the cruise control disengages you have a short or bad ground. If it doesn't you probably have two wires backwards or an incorrect/misplaced bulb
    Feb 2004
    '01 Ebony #0830
    Hi,
    No LED. Just stock.
    This all happened suddenly this morning.
    I'll try the cruise trick too.
    thanks!
    Hoping it's just a blown bulb...
    Feb 2004
    '01 Ebony #0830
    Thumbs up Fixed!!!
    Special thanks to Master Jedi Tom4Bren!!!
    It turned out to be both a burned/blown brake light bulb AND a blown trailer wiring adapter! I tried regrounding it to no avail. Then removed one wire, and fixed! (It was hot too!).
    So I pulled the adapter out. I'll replace it later.
    Thanks again!
    Funny, I noticed one of my tail lights was acting up when I left Friday night from work. Luckily, I decided to take a walk around my VX while it was idling in the parking a lot at work before I left while I finished a smoke. I noticed my passenger side tail light was "fluttering". Just the parking light. When the brake was pressed, it was solid.
    Now, I had done a complete light modification many years ago which meant cracking open the light, tinting the inner assembly (smoked) and putting LED bulbs in. This issue is quite new and from the looks of it, one of the LEDs is starting to give up the ghost or I have a short. Time to pry through and see what the gremlins have done....
  1. turn signal relay ??
    By orion in forum VX Troubleshooting...
    Last Post: 07/13/2014, 09:23 AM
  2. turn signal help
    By dsallade01 in forum VX Troubleshooting...
    Last Post: 06/28/2011, 07:44 AM
  3. Turn Signal Lens
    By SomeBeach in forum VX Talk...
    Last Post: 07/01/2009, 07:05 AM
  4. turn signal problem
    By hemicross in forum VX Troubleshooting...
    Last Post: 02/10/2009, 12:29 PM
  5. Water in turn signal.
    By tomcat837 in forum VX Troubleshooting...
    Last Post: 04/18/2004, 07:33 AM
