The low tech solution would be to put a piece of duct tape around the drive shaft making a flag. When you drive, if the front drive shaft is spinning, the loud whirring sound lets you know. If you make the flag long enough to slap the floorboard, then you'll REALLY know.
Actually I'm just kidding. I don't know how much weight it takes to throw a drive shaft out of balance ... & I don't want to find out with MY VX.
Or the old trick for the mates wedding car - tie an elastic band around the shaft with a steel washer at the end of it.
Faster he goes, the more noise it makes.
PK
