I am stoked for the SFIFS kits! It's taking all i have to patiently wait![]()
Most of the interest in SFIFS is on the planet, good to know there's someone here that wants a kit. I'm just finalizing a new design to make the pin more accessible. I'm also working on an pnuematic setup for the pin with a cab push button. If the pneumatic system works, it will be an order option. I should have some pricing information from the machine shop in 2-3 weeks.
This will likely be a one time deal.![]()
Cool to see the SFIFS in action on your rig and glad someone got some scientific numbers. That pin is a total pain so I can't wait for your solution to it. Glad I could have a small part in helping out the Isuzu community with the kit.
Keep up the good work!
Thanks JMNY.
Few updates:
1.) Headlights ND92 now has my projector/LED headlights and I have his OEM headlights. I'm back to original.
2.) Switches & Air Pressure Gauge I have three sets of trail lights on the VX and decided it was time to wire them to a proper switch panel. I also wanted switches for the air compressor and future air lockers. I found customized switches on otrattw.com.
The 6 slot switch holder that otrattw sells fits nicely in the lower dash bezel. I can take install pics if someone decides to get the same switch setup. I haven't wired everything up yet but the symbols will light up blue with the interior lights. Overall the switches cost around $110.
Also, I decided it was a good time to install an air pressure gauge in the dash. I just relocated the 12v outlet to the center console and installed the air pressure gauge in it's place. I plan on ordering a lit gauge so I can see my air pressure at night. I'll post more pics when that's installed.
3.) CB Radio & Antenna I decided to purchase the Cobra 75XTST compact unit. Several members here including VXKAT & Marlin have had good results with this CB radio. The CB Radio costs $93 at CBworld.com
I always wanted to install a 102" whip on the VX and purchased one locally at RadioShack. I built a CB antenna mount and tied the whip down for daily driving. I really like the look of the whip but it's impractical for trails. I also have a 2 ft Firestick that will work better for most situations.
Whip Antenna
Whip Antenna
Firestick Antenna
Firestick Antenna
New Switches, Air Pressure Gauge & CB Radio
Switches and Air Pressure Gauge in OEM bezel- Zombie Lights probably belong on DUB's Vehicross
Installed LED lights in cargo area that turn on with doors/key fob. I purchased the lights from Clipper Rodeo 03
Installed new tire cover knobs from Jason
Really nice to find switches with the actual correct labels. Lookin' great Jon, wish I had time to do as much stuff on my VX!
so why the headlight change?
Looking great as always Jon! I really like that switch panel, I am actually planning to put one in the same spot for all my lights.
for 139.00 plus free shipping....found it doing some searches.....just in case anyone is interested...at Hitch anything.com
"KILLER BEE":
I had a black hood/ironman and built the headlights to match. I originally was going to wrap the VX in matte black but found it scratched too easily. Once I wrapped the VX in blue, I decided the OEM reflectors would look better.
Definitely use the CD changer bezel if you're not using it becuase the fit is almost perfect.
I removed my Yakima bars because it mounted the basket too high and I wanted clear my garage door. I made my own mounts similar too Zeus' write-up in the how-to section.
