After a long debate with myself, I decided to go with ORI Struts vs coil-overs. I stumbled across these while researching coil-over towers and something about them just cried out "buy me." Of course I did a good amount of research on them first; after all I've only heard bad things about air shocks. Seems like 90% of everyone who owns ORI struts swears by them.
Pros:
Fully and easily tunable, height adjustable
Internal hydraulic bump stops- no need for external bump stops and limiting straps
Very stable- no sway bar needed
No unloading
Cons:
No physical spring holding up the vehicle
Noticeable shock fade for high speed racing
They're a lot more complex than air shocks. They use opposing nitrogen reservoirs that split the task of damping and lift. Because of the separate sections, they're very stable & eliminate unloading. They’re very adjustable too and allow you to change everything in a matter of minutes. To adjust them, I needed to buy a nitrogen tank & regulator which added to the cost. They’re also more expensive than coil-overs but the cost evens by not needing bump stops, limit straps or a swaybar.
We’ll see, I hope they work out well for my setup.
