With Aquaponics, the plants grow the fish and the fish grow the plants... Is your mind not yet blown??? Well then, let me add that there is no fertilization needed for the plants either and all you need to do is add water!![]()
Hello Jheyson, it seems like you may have a distorted view when it comes to differentiating alcohol from other drugs. Yes, alcohol is just another drug, same with caffeine and nicotine. Each drug sends different signals to your brain which enhance and impair different parts of said fatty matter.
The key difference between driving drunk and driving stoned is this:
Alcohol is a depressant because it slows down the functions of the central nervous system. This means that normal brain function is delayed, and a person is unable to function normally. Alcohol affects a person's information-processing skills, also known as cognitive skills, and hand-eye coordination, also referred to as psychomotor skills.
Consuming alcohol prior to driving greatly increases the risk of car accidents, highway injuries, and vehicular deaths. The greater the amount of alcohol consumed, the more likely a person is to be involved in an accident.
(taken from http://www.duifoundation.org/drunkdriving/impairment/)
Although cannabis intoxication has been shown to mildly impair psychomotor skills, this impairment does not appear to be severe or long lasting. In driving simulator tests, this impairment is typically manifested by subjects decreasing their driving speed and requiring greater time to respond to emergency situations.
(taken from http://norml.org/library/item/mariju...tific-evidence)
Jheyson, if you've read this far then I thank you for your time and consideration on this matter and ask that you please do some research before setting any opinion either for or against marijuana/alcohol/any other drug.
