Results 1 to 5 of 5
Thread: O2 sensor change
    Feb 2012
    Looking to buy
    O2 sensor change
    OK, I'm getting the P1133 code so I'm trying to change the B1S1 sensor (passenger side front according to the manual). I got the sensor out but can't get at the electrical connector! My moose hands won't fit up there. Do I have to do some major disassembly here or is there an easier way that doesn't cost me a lot of skin loss. Appreciate any help I can get.
    Wrench You might not like hearing this but...
    Many times when you're getting O2 sensor codes, especially when combined with "lean during acceleration" codes...it's the intake gaskets...
    Mar 2011
    99, Orange, VX, 0398
    I did both of mine (upstream of the exhaust) a couple month ago. lost a lot of skin... I took the big cross member out and lowered it with a jack. That allowed me to get at the electrical connector (still difficult and painful but better). there was a plastic tab that held the wire in place against the frame. I was able to remove it which gave me more wiggle room. Couldn't get it back but I think that was fine. I got it all back together and still had the code
    Feb 2012
    Looking to buy
    Sigh...hopefully it's just the O2 sensor. Really don't wanna mess with gaskets at the moment. I looked at the cross member but was hoping someone figured a great and spectacular fix! Ah well, gonna be doing ball joints and CV boot next week so I guess I'll add a crossmember removal to the list.
    1999,silver,vehicross,1891
    up streat sensors
    those cats come off the header pipes pretty easy, 3 nuts each, a common brass ring is the seal, got new ones from NAPA before I put the refished/polished cats back up; at $20 a sensor I wish I has just replaced all 4 O2 sensors now, my only code since doing tranny rebuild and exhaust work is PO140 / P0140, I think I just need to replace my rear ones, much easier to get to
  1. Which O2 sensor is Bank1 sensor 1
    By Ebenezr in forum VX Troubleshooting...
    Last Post: 08/05/2014, 06:55 AM
  2. MAP sensor
    By IronManVC in forum VX Troubleshooting...
    Last Post: 03/13/2012, 06:50 AM
  3. re abs sensor?
    Last Post: 02/24/2012, 02:31 PM
  4. MAF Sensor
    Last Post: 02/11/2011, 12:44 PM
  5. O2 Sensor/Coolant Temperature Sensor
    Last Post: 04/21/2007, 01:50 AM
